[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_les.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jun 4 17:18:37 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_les.c functions
N_alloc_spvector (Begins at: 29 Ends at: 53)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 25 | | OK |
metrics are OK
N_alloc_nquad_les (Begins at: 55 Ends at: 69)
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
N_alloc_nquad_les_Ax (Begins at: 71 Ends at: 85)
LOC: | 15 | | OK |
metrics are OK
N_alloc_nquad_les_A (Begins at: 87 Ends at: 101)
LOC: | 15 | | OK |
metrics are OK
N_alloc_nquad_les_Ax_b (Begins at: 103 Ends at: 118)
LOC: | 16 | | OK |
metrics are OK
N_alloc_les (Begins at: 120 Ends at: 133)
ParamNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
N_alloc_les_Ax (Begins at: 135 Ends at: 148)
LOC: | 14 | | OK |
metrics are OK
N_alloc_les_A (Begins at: 150 Ends at: 163)
LOC: | 14 | | OK |
metrics are OK
N_alloc_les_Ax_b (Begins at: 165 Ends at: 196)
LOC: | 32 | | OK |
metrics are OK
N_alloc_les_param (Begins at: 198 Ends at: 261)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 64 | | OK |
metrics are OK
N_add_spvector_to_les (Begins at: 263 Ends at: 310)
Complexity: | 4 | | OK |
LOC: | 48 | | OK |
metrics are OK
N_print_les (Begins at: 312 Ends at: 361)
Complexity: | 8 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 50 | | OK |
metrics are OK
N_free_spvector (Begins at: 363 Ends at: 385)
CalledNBR: | 3 | | OK |
LOC: | 23 | | OK |
metrics are OK
N_free_les (Begins at: 387 Ends at: 428)
Complexity: | 10 | | OK |
LOC: | 42 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
