[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_solvers.c |2 clones ( N_les_assemble.c N_solvers.c )| 0 monsters | 0 warnings
Mon Jun 4 17:48:12 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_solvers.c functions
N_solver_gauss (Begins at: 45 Ends at: 76)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
N_solver_lu (Begins at: 78 Ends at: 140)
CalledNBR:    |      14 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
gauss_elimination (Begins at: 142 Ends at: 170)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
lu_decomposition (Begins at: 172 Ends at: 203)
LOC:          |      32 |       |      OK |
metrics are OK
backward_solving (Begins at: 205 Ends at: 233)
ParamNBR:     |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
forward_solving (Begins at: 235 Ends at: 249)
LOC:          |      15 |       |      OK |
metrics are OK
thomalg (Begins at: 255 Ends at: 297)
CalledNBR:    |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
vectmem (Begins at: 299 Ends at: 305)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  gauss_seidel  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  gauss_seidel are:
	lib/gpde/N_solvers_classic_iter.c  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  jacobi are:
	lib/gpde/N_solvers_classic_iter.c  gauss_seidel
Threshold GRASS6 key metrics values at 2007-06-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
