[GRASS-QA] GRASS QA: soeren |
	./grass6/lib/gpde/N_solvers_classic_iter.c |2 clones (
	N_les_assemble.c N_solvers.c N_solvers_classic_iter.c )| 0
	monsters | 2 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Jun  4 17:48:12 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_solvers_classic_iter.c functions
N_solver_jacobi (Begins at: 53 Ends at: 88)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
N_solver_SOR (Begins at: 90 Ends at: 103)
LOC:          |      14 |       |      OK |
metrics are OK
sparse_jacobi_gauss (Begins at: 109 Ends at: 165)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
jacobi (Begins at: 170 Ends at: 203)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
at least 1 values are close to an outlier please consider revising code
gauss_seidel (Begins at: 208 Ends at: 241)
LOC:          |      34 |       |      OK |
Clone analysis:
This file has 2 potentially cloned functions:
  gauss_seidel  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  gauss_seidel are:
	lib/gpde/N_solvers_classic_iter.c  jacobi
In lib/gpde/N_solvers_classic_iter.c clones of  jacobi are:
	lib/gpde/N_solvers_classic_iter.c  gauss_seidel
Threshold GRASS6 key metrics values at 2007-06-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
