[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_solvers_krylov.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Jun  4 17:48:12 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_solvers_krylov.c functions
N_solver_pcg (Begins at: 63 Ends at: 231)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     169 |     * |         |
metrics are OK
N_solver_cg (Begins at: 233 Ends at: 390)
CalledNBR:    |      29 |       |      OK |
LOC:          |     158 |     * |         |
metrics are OK
N_solver_bicgstab (Begins at: 392 Ends at: 543)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     152 |     * |         |
metrics are OK
scalar_product (Begins at: 545 Ends at: 569)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
N_matrix_vector_product (Begins at: 571 Ends at: 597)
LOC:          |      27 |       |      OK |
metrics are OK
N_sparse_matrix_vector_product (Begins at: 599 Ends at: 627)
LOC:          |      29 |       |      OK |
metrics are OK
add_vectors_scalar2 (Begins at: 630 Ends at: 654)
ParamNBR:     |       6 |     * |         |
LOC:          |      25 |       |      OK |
metrics are OK
add_vectors_scalar (Begins at: 657 Ends at: 681)
ParamNBR:     |       5 |     * |         |
LOC:          |      25 |       |      OK |
metrics are OK
sub_vectors_scalar (Begins at: 684 Ends at: 707)
LOC:          |      24 |       |      OK |
metrics are OK
add_vectors (Begins at: 709 Ends at: 731)
LOC:          |      23 |       |      OK |
metrics are OK
sub_vectors (Begins at: 733 Ends at: 755)
LOC:          |      23 |       |      OK |
metrics are OK
scalar_vector_product (Begins at: 757 Ends at: 775)
LOC:          |      19 |       |      OK |
metrics are OK
sync_vectors (Begins at: 777 Ends at: 798)
LOC:          |      22 |       |      OK |
metrics are OK
check_symmetry (Begins at: 800 Ends at: 871)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
N_create_diag_precond_matrix (Begins at: 873 Ends at: 903)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
