[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.stats/main.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Jun  4 17:48:13 EDT 2007
Hello soeren,
ANALYSIS
raster3d/r3.stats/main.c functions
alloc_equal_val_array (Begins at: 73 Ends at: 89)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
add_equal_val_to_array (Begins at: 94 Ends at: 123)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
check_equal_value (Begins at: 128 Ends at: 148)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
free_equal_val_array (Begins at: 154 Ends at: 167)
LOC:          |      14 |       |      OK |
metrics are OK
create_stat_table (Begins at: 173 Ends at: 249)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      77 |       |      OK |
metrics are OK
free_stat_table (Begins at: 254 Ends at: 269)
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
update_stat_table (Begins at: 274 Ends at: 296)
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
print_stat_table (Begins at: 301 Ends at: 354)
CalledNBR:    |       9 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
check_range_value (Begins at: 359 Ends at: 407)
CalledNBR:    |       1 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
tree_search_range (Begins at: 409 Ends at: 477)
Complexity:   |      10 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
heapsort_eqvals (Begins at: 483 Ends at: 504)
LOC:          |      22 |       |      OK |
metrics are OK
downheap_eqvals (Begins at: 510 Ends at: 535)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
main (Begins at: 541 Ends at: 715)
Complexity:   |      17 |     * |         |
CalledNBR:    |      52 |     * |         |
LOC:          |     175 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
