[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays_calc.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Jun  5 18:19:17 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays_calc.c functions
N_copy_array_2d (Begins at: 43 Ends at: 141)
Complexity:   |      24 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
N_norm_array_2d (Begins at: 143 Ends at: 212)
Complexity:   |      18 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
N_calc_array_2d_stats (Begins at: 214 Ends at: 297)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
N_math_array_2d (Begins at: 299 Ends at: 417)
Complexity:   |      23 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |     119 |       |      OK |
metrics are OK
N_convert_array_2d_null_to_zero (Begins at: 419 Ends at: 483)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
N_copy_array_3d (Begins at: 485 Ends at: 557)
Complexity:   |      14 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
N_norm_array_3d (Begins at: 559 Ends at: 623)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
N_calc_array_3d_stats (Begins at: 625 Ends at: 718)
LOC:          |      94 |       |      OK |
metrics are OK
N_math_array_3d (Begins at: 720 Ends at: 827)
Complexity:   |      22 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     108 |       |      OK |
metrics are OK
N_convert_array_3d_null_to_zero (Begins at: 829 Ends at: 864)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
