[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/lib/lrs.c |no clones | 3 monsters | 0 warnings
Sat Jun 23 04:04:27 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/lib/lrs.c functions
cmp_rsegment (Begins at: 46 Ends at: 59)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
LR_get_milepost (Begins at: 61 Ends at: 232)
Complexity:   |      11 |       |      OK |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      46 |     * |         |
LOC:          |     172 |     * |         |
1 metric are OUT OF RANGE!
LR_get_offset (Begins at: 234 Ends at: 267)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      34 |       |      OK |
offset_in_rsegment (Begins at: 269 Ends at: 332)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
LR_get_nearest_offset (Begins at: 334 Ends at: 563)
Complexity:   |      20 |     * |         |
ParamNBR:     |      17 |   *** | MONSTER |
CalledNBR:    |      56 |     * |         |
LOC:          |     230 |    ** | Warning |
LR_cmp_mileposts (Begins at: 570 Ends at: 596)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
