[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/select.c |no clones | 0 monsters | 0 warnings
Sat Jun 23 04:04:27 EDT 2007
Hello markus,
ANALYSIS
lib/db/dbmi_client/select.c functions
cmp (Begins at: 6 Ends at: 14)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
cmpcat (Begins at: 16 Ends at: 24)
LOC:          |       9 |       |      OK |
metrics are OK
cmpcatkey (Begins at: 26 Ends at: 34)
LOC:          |       9 |       |      OK |
metrics are OK
cmpvalueint (Begins at: 36 Ends at: 45)
LOC:          |      10 |       |      OK |
metrics are OK
cmpvaluedouble (Begins at: 47 Ends at: 56)
LOC:          |      10 |       |      OK |
metrics are OK
cmpvaluestring (Begins at: 58 Ends at: 75)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
db_select_int (Begins at: 77 Ends at: 165)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
db_select_value (Begins at: 167 Ends at: 212)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
db_select_CatValArray (Begins at: 214 Ends at: 325)
Complexity:   |      16 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
db_CatValArray_sort (Begins at: 333 Ends at: 336)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
db_CatValArray_sort_by_value (Begins at: 345 Ends at: 374)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
db_CatValArray_get_value (Begins at: 377 Ends at: 395)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
db_CatValArray_get_value_int (Begins at: 398 Ends at: 416)
LOC:          |      19 |       |      OK |
metrics are OK
db_CatValArray_get_value_double (Begins at: 419 Ends at: 431)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
