[GRASS-QA] GRASS QA: carlos | ./grass6/general/g.proj/output.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Jun 25 13:14:55 EDT 2007
Hello carlos,
ANALYSIS
general/g.proj/output.c functions
print_projinfo (Begins at: 28 Ends at: 48)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 21 | | OK |
metrics are OK
print_datuminfo (Begins at: 50 Ends at: 92)
Complexity: | 8 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 43 | | OK |
metrics are OK
print_proj4 (Begins at: 94 Ends at: 126)
Complexity: | 5 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 33 | | OK |
metrics are OK
print_wkt (Begins at: 128 Ends at: 145)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 18 | | OK |
metrics are OK
create_location (Begins at: 147 Ends at: 242)
Complexity: | 16 | * | |
CalledNBR: | 46 | * | |
LOC: | 96 | | OK |
metrics are OK
check_xy (Begins at: 244 Ends at: 252)
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
