[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/index.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:21 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/index.c functions
db_init_index (Begins at: 12 Ends at: 20)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
db_free_index (Begins at: 29 Ends at: 37)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
db_alloc_index_columns (Begins at: 46 Ends at: 55)
ParamNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
db_alloc_index_array (Begins at: 64 Ends at: 77)
LOC: | 14 | | OK |
metrics are OK
db_free_index_array (Begins at: 86 Ends at: 97)
LOC: | 12 | | OK |
metrics are OK
db_set_index_name (Begins at: 106 Ends at: 110)
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_get_index_name (Begins at: 119 Ends at: 123)
LOC: | 5 | | OK |
metrics are OK
db_set_index_table_name (Begins at: 132 Ends at: 136)
LOC: | 5 | | OK |
metrics are OK
db_get_index_table_name (Begins at: 145 Ends at: 149)
LOC: | 5 | | OK |
metrics are OK
db_get_index_number_of_columns (Begins at: 158 Ends at: 162)
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_set_index_column_name (Begins at: 171 Ends at: 180)
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
db_get_index_column_name (Begins at: 189 Ends at: 198)
LOC: | 10 | | OK |
metrics are OK
db_set_index_type_unique (Begins at: 207 Ends at: 212)
LOC: | 6 | | OK |
metrics are OK
db_set_index_type_non_unique (Begins at: 221 Ends at: 226)
LOC: | 6 | | OK |
metrics are OK
db_test_index_type_unique (Begins at: 235 Ends at: 238)
LOC: | 4 | | OK |
metrics are OK
db_print_index (Begins at: 247 Ends at: 263)
CalledNBR: | 11 | | OK |
LOC: | 17 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
