[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/handle.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:21 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/handle.c functions
db_init_handle (Begins at: 11 Ends at: 16)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
db_set_handle (Begins at: 24 Ends at: 34)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
db_get_handle_dbname (Begins at: 43 Ends at: 47)
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_get_handle_dbschema (Begins at: 56 Ends at: 60)
LOC: | 5 | | OK |
metrics are OK
db_free_handle (Begins at: 69 Ends at: 74)
LOC: | 6 | | OK |
metrics are OK
db_free_handle_array (Begins at: 83 Ends at: 94)
ParamNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
db_alloc_handle_array (Begins at: 103 Ends at: 114)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
