[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/datetime.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:21 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/datetime.c functions
db_convert_value_datetime_into_string (Begins at: 14 Ends at: 185)
Complexity: | 49 | *** | MONSTER |
ParamNBR: | 3 | | OK |
CalledNBR: | 34 | | OK |
LOC: | 172 | * | |
1 metric are OUT OF RANGE!
db_convert_Cstring_to_value_datetime (Begins at: 187 Ends at: 328)
Complexity: | 45 | *** | MONSTER |
CalledNBR: | 33 | | OK |
LOC: | 142 | * | |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
