[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/window.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:23 EST 2007
Hello glynn,
ANALYSIS
lib/display/window.c functions
D_new_window (Begins at: 60 Ends at: 110)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 11 | | OK |
LOC: | 51 | | OK |
metrics are OK
D_set_cur_wind (Begins at: 112 Ends at: 185)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 74 | | OK |
metrics are OK
D_get_cur_wind (Begins at: 187 Ends at: 220)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 34 | | OK |
metrics are OK
D_show_window (Begins at: 222 Ends at: 253)
Complexity: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 32 | | OK |
metrics are OK
D_get_screen_window (Begins at: 255 Ends at: 284)
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
D_check_map_window (Begins at: 286 Ends at: 346)
Complexity: | 9 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 61 | | OK |
metrics are OK
D_reset_screen_window (Begins at: 348 Ends at: 375)
CalledNBR: | 7 | | OK |
LOC: | 28 | | OK |
metrics are OK
D_timestamp (Begins at: 377 Ends at: 418)
ParamNBR: | 0 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 42 | | OK |
metrics are OK
D_remove_window (Begins at: 420 Ends at: 441)
Complexity: | 1 | | OK |
LOC: | 22 | | OK |
metrics are OK
D_erase_window (Begins at: 443 Ends at: 454)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
