[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/line.c |no clones | 0 monsters | 1 warnings
Thu Mar 1 19:38:28 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/line.c functions
write_line (Begins at: 15 Ends at: 86)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |      72 |       |      OK |
metrics are OK
snap (Begins at: 89 Ends at: 110)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
new_line (Begins at: 113 Ends at: 221)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      50 |     * |         |
LOC:          |     109 |       |      OK |
metrics are OK
edit_line (Begins at: 224 Ends at: 370)
Complexity:   |      17 |     * |         |
CalledNBR:    |      64 |    ** | Warning |
LOC:          |     147 |     * |         |
at least 1 values are close to an outlier please consider revising code
delete_line (Begins at: 373 Ends at: 473)
CalledNBR:    |      43 |     * |         |
LOC:          |     101 |       |      OK |
metrics are OK
move_line (Begins at: 476 Ends at: 574)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |      99 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
