[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/line.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:28 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/line.c functions
write_line (Begins at: 15 Ends at: 86)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 44 | * | |
LOC: | 72 | | OK |
metrics are OK
snap (Begins at: 89 Ends at: 110)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 22 | | OK |
metrics are OK
new_line (Begins at: 113 Ends at: 221)
Complexity: | 13 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 50 | * | |
LOC: | 109 | | OK |
metrics are OK
edit_line (Begins at: 224 Ends at: 370)
Complexity: | 17 | * | |
CalledNBR: | 64 | ** | Warning |
LOC: | 147 | * | |
at least 1 values are close to an outlier please consider revising code
delete_line (Begins at: 373 Ends at: 473)
CalledNBR: | 43 | * | |
LOC: | 101 | | OK |
metrics are OK
move_line (Begins at: 476 Ends at: 574)
Complexity: | 11 | | OK |
CalledNBR: | 39 | * | |
LOC: | 99 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
