[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.profile/main.c |1 clones ( curses.c graphics.c mouse.c signature.c plot.c main.c main.c main.c main.c main.c main.c graphics.c graphics.c graphics.c graphics.c graphics.c c_update.c d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c raster_rgb.c Get_location.c com_proto.c com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c i_face.c main.c main.c )| 2 monsters | 0 warnings
Thu Mar 1 19:38:31 EST 2007
Hello hamish,
ANALYSIS
raster/r.profile/main.c functions
main (Begins at: 25 Ends at: 279)
Complexity:   |      23 |     * |         |
CalledNBR:    |     101 |   *** | MONSTER |
LOC:          |     255 |    ** | Warning |
1 metric are OUT OF RANGE!
do_profile (Begins at: 283 Ends at: 385)
Complexity:   |      18 |     * |         |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      27 |       |      OK |
LOC:          |     103 |       |      OK |
move (Begins at: 387 Ends at: 392)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
cont (Begins at: 394 Ends at: 415)
Complexity:   |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cont
In raster/r.profile/main.c clones of  cont are:
	display/d.nviz/main.c  cont
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
