[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/c_face.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:27 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/c_face.c functions
c_cancel (Begins at: 20 Ends at: 26)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
c_next_tool (Begins at: 30 Ends at: 96)
Complexity: | 24 | * | |
CalledNBR: | 27 | | OK |
LOC: | 67 | | OK |
metrics are OK
c_set_color (Begins at: 100 Ends at: 125)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 26 | | OK |
metrics are OK
c_set_on (Begins at: 129 Ends at: 151)
CalledNBR: | 7 | | OK |
LOC: | 23 | | OK |
metrics are OK
c_tool_centre (Begins at: 154 Ends at: 160)
LOC: | 7 | | OK |
metrics are OK
c_table_definition (Begins at: 164 Ends at: 214)
Complexity: | 5 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 51 | | OK |
metrics are OK
c_create_table (Begins at: 218 Ends at: 311)
Complexity: | 7 | | OK |
CalledNBR: | 72 | ** | Warning |
LOC: | 94 | | OK |
at least 1 values are close to an outlier please consider revising code
c_var_set (Begins at: 315 Ends at: 343)
LOC: | 29 | | OK |
metrics are OK
c_create_bgcmd (Begins at: 347 Ends at: 358)
LOC: | 12 | | OK |
metrics are OK
c_set_bgcmd (Begins at: 362 Ends at: 383)
Complexity: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
c_add_blank_bgcmd (Begins at: 387 Ends at: 402)
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
c_del_cat (Begins at: 406 Ends at: 426)
LOC: | 21 | | OK |
metrics are OK
c_add_cat (Begins at: 430 Ends at: 456)
CalledNBR: | 8 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
