[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/display.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:28 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/display.c functions
display_points (Begins at: 22 Ends at: 35)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
display_icon (Begins at: 38 Ends at: 47)
ParamNBR: | 6 | * | |
LOC: | 10 | | OK |
metrics are OK
display_line (Begins at: 55 Ends at: 82)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
display_updated_lines (Begins at: 86 Ends at: 96)
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 11 | | OK |
metrics are OK
display_node (Begins at: 103 Ends at: 118)
Complexity: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
display_updated_nodes (Begins at: 122 Ends at: 135)
Complexity: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
display_map (Begins at: 138 Ends at: 186)
Complexity: | 8 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 49 | | OK |
metrics are OK
display_bg (Begins at: 189 Ends at: 201)
CalledNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
display_erase (Begins at: 204 Ends at: 216)
Complexity: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
display_redraw (Begins at: 219 Ends at: 224)
CalledNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
