[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/display.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:28 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/display.c functions
display_points (Begins at: 22 Ends at: 35)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
display_icon (Begins at: 38 Ends at: 47)
ParamNBR:     |       6 |     * |         |
LOC:          |      10 |       |      OK |
metrics are OK
display_line (Begins at: 55 Ends at: 82)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
display_updated_lines (Begins at: 86 Ends at: 96)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
display_node (Begins at: 103 Ends at: 118)
Complexity:   |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
display_updated_nodes (Begins at: 122 Ends at: 135)
Complexity:   |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
display_map (Begins at: 138 Ends at: 186)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
display_bg (Begins at: 189 Ends at: 201)
CalledNBR:    |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
display_erase (Begins at: 204 Ends at: 216)
Complexity:   |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
display_redraw (Begins at: 219 Ends at: 224)
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
