[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/g3dmisc.c |4 clones
( curses.c graphics.c mouse.c signature.c plot.c main.c
main.c main.c main.c main.c main.c graphics.c graphics.c
graphics.c graphics.c graphics.c c_update.c d_drop_index.c
d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c
raster_rgb.c Get_location.c com_proto.c com_proto.c
com_proto.c loc_proto.c loc_proto.c loc_proto.c i_face.c
main.c main.c level_two.c main.c build.c line.c read_nat.c
areas.c filecompare.c g3dfpxdr.c g3dmisc.c )| 0 monsters | 1
warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/g3dmisc.c functions
G3d_g3dType2cellType (Begins at: 12 Ends at: 17)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
G3d_copyFloat2Double (Begins at: 22 Ends at: 31)
ParamNBR: | 5 | * | |
LOC: | 10 | | OK |
metrics are OK
G3d_copyDouble2Float (Begins at: 36 Ends at: 45)
LOC: | 10 | | OK |
metrics are OK
G3d_copyValues (Begins at: 50 Ends at: 75)
Complexity: | 4 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 3 | | OK |
LOC: | 26 | | OK |
at least 1 values are close to an outlier please consider revising code
G3d_length (Begins at: 80 Ends at: 88)
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
G3d_externLength (Begins at: 91 Ends at: 99)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
G3d_externLength G3d_length G3d_copyDouble2Float G3d_copyFloat2Double
In lib/g3d/g3dmisc.c clones of G3d_copyDouble2Float are:
lib/g3d/g3dmisc.c G3d_copyFloat2Double
In lib/g3d/g3dmisc.c clones of G3d_length are:
lib/g3d/g3dmisc.c G3d_externLength
In lib/g3d/g3dmisc.c clones of G3d_copyFloat2Double are:
lib/g3d/g3dmisc.c G3d_copyDouble2Float
In lib/g3d/g3dmisc.c clones of G3d_externLength are:
lib/g3d/g3dmisc.c G3d_length
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
