[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/g3dnull.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/g3dnull.c functions
G3d_isNullValueNum (Begins at: 10 Ends at: 32)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 23 | | OK |
metrics are OK
G3d_setNullValue (Begins at: 35 Ends at: 44)
ParamNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
