[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_proto.c |5
clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c )| 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:25 EST 2007
Hello glynn,
ANALYSIS
lib/raster/com_proto.c functions
R_screen_left (Begins at: 24 Ends at: 36)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
R_screen_rite (Begins at: 38 Ends at: 50)
LOC: | 13 | | OK |
metrics are OK
R_screen_bot (Begins at: 52 Ends at: 65)
LOC: | 14 | | OK |
metrics are OK
R_screen_top (Begins at: 67 Ends at: 70)
LOC: | 4 | | OK |
metrics are OK
R_get_num_colors (Begins at: 72 Ends at: 85)
LOC: | 14 | | OK |
metrics are OK
R_color (Begins at: 87 Ends at: 102)
LOC: | 16 | | OK |
metrics are OK
R_standard_color (Begins at: 104 Ends at: 121)
LOC: | 18 | | OK |
metrics are OK
R_RGB_color (Begins at: 123 Ends at: 139)
ParamNBR: | 3 | | OK |
LOC: | 17 | | OK |
metrics are OK
R_reset_color (Begins at: 141 Ends at: 160)
ParamNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
R_reset_colors (Begins at: 162 Ends at: 175)
ParamNBR: | 5 | * | |
LOC: | 14 | | OK |
metrics are OK
R_line_width (Begins at: 177 Ends at: 189)
LOC: | 13 | | OK |
metrics are OK
R_erase (Begins at: 191 Ends at: 205)
LOC: | 15 | | OK |
metrics are OK
R_move_abs (Begins at: 207 Ends at: 225)
ParamNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
R_move_rel (Begins at: 227 Ends at: 242)
LOC: | 16 | | OK |
metrics are OK
R_cont_abs (Begins at: 244 Ends at: 264)
LOC: | 21 | | OK |
metrics are OK
R_cont_rel (Begins at: 266 Ends at: 282)
LOC: | 17 | | OK |
metrics are OK
R_polydots_abs (Begins at: 284 Ends at: 302)
LOC: | 19 | | OK |
metrics are OK
R_polydots_rel (Begins at: 304 Ends at: 323)
LOC: | 20 | | OK |
metrics are OK
R_polyline_abs (Begins at: 325 Ends at: 345)
LOC: | 21 | | OK |
metrics are OK
R_polyline_rel (Begins at: 347 Ends at: 363)
LOC: | 17 | | OK |
metrics are OK
R_polygon_abs (Begins at: 365 Ends at: 383)
LOC: | 19 | | OK |
metrics are OK
R_polygon_rel (Begins at: 385 Ends at: 402)
LOC: | 18 | | OK |
metrics are OK
R_box_abs (Begins at: 404 Ends at: 420)
LOC: | 17 | | OK |
metrics are OK
R_box_rel (Begins at: 422 Ends at: 435)
LOC: | 14 | | OK |
metrics are OK
R_text_size (Begins at: 437 Ends at: 440)
LOC: | 4 | | OK |
metrics are OK
R_text_rotation (Begins at: 442 Ends at: 458)
LOC: | 17 | | OK |
metrics are OK
R_set_window (Begins at: 460 Ends at: 473)
LOC: | 14 | | OK |
metrics are OK
R_text (Begins at: 475 Ends at: 495)
LOC: | 21 | | OK |
metrics are OK
R_get_text_box (Begins at: 497 Ends at: 532)
LOC: | 36 | | OK |
metrics are OK
R_font (Begins at: 534 Ends at: 537)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype (Begins at: 539 Ends at: 542)
LOC: | 4 | | OK |
metrics are OK
R_charset (Begins at: 544 Ends at: 547)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype_release (Begins at: 549 Ends at: 552)
LOC: | 4 | | OK |
metrics are OK
R_panel_save (Begins at: 554 Ends at: 557)
LOC: | 4 | | OK |
metrics are OK
R_panel_restore (Begins at: 559 Ends at: 562)
LOC: | 4 | | OK |
metrics are OK
R_panel_delete (Begins at: 564 Ends at: 583)
LOC: | 20 | | OK |
metrics are OK
R_set_RGB_color (Begins at: 585 Ends at: 611)
LOC: | 27 | | OK |
metrics are OK
R_RGB_raster (Begins at: 613 Ends at: 649)
ParamNBR: | 6 | * | |
LOC: | 37 | | OK |
metrics are OK
R_raster_char (Begins at: 651 Ends at: 654)
LOC: | 4 | | OK |
metrics are OK
R_raster_int (Begins at: 656 Ends at: 659)
LOC: | 4 | | OK |
metrics are OK
R_bitmap (Begins at: 661 Ends at: 664)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
R_set_window R_cont_rel R_RGB_raster R_reset_colors R_text
In lib/raster/com_proto.c clones of R_text are:
lib/raster/loc_proto.c LOC_text
In lib/raster/com_proto.c clones of R_cont_rel are:
lib/raster/loc_proto.c LOC_cont_rel
In lib/raster/com_proto.c clones of R_set_window are:
lib/raster/loc_proto.c LOC_set_window
In lib/raster/com_proto.c clones of R_reset_colors are:
lib/raster/loc_proto.c LOC_reset_colors
In lib/raster/com_proto.c clones of R_RGB_raster are:
lib/raster/loc_proto.c LOC_RGB_raster
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
