[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/common.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:25 EST 2007
Hello glynn,
ANALYSIS
lib/raster/common.c functions
R_flush (Begins at: 17 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
R_set_update_function (Begins at: 31 Ends at: 42)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
R_call_update_function (Begins at: 44 Ends at: 48)
Complexity:   |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R_has_update_function (Begins at: 56 Ends at: 59)
LOC:          |       4 |       |      OK |
metrics are OK
R_set_cancel (Begins at: 70 Ends at: 73)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_cancel (Begins at: 81 Ends at: 101)
LOC:          |      21 |       |      OK |
metrics are OK
R_raster (Begins at: 103 Ends at: 133)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
R_pad_perror (Begins at: 135 Ends at: 152)
Complexity:   |      10 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
R_pad_freelist (Begins at: 154 Ends at: 165)
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
