[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.to.vect/lines.c
	|no clones | 2 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Mar  1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.to.vect/lines.c functions
extract_lines (Begins at: 62 Ends at: 185)
Complexity:   |      18 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     124 |     * |         |
metrics are OK
nabors (Begins at: 187 Ends at: 209)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
update_list (Begins at: 211 Ends at: 484)
Complexity:   |      79 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     274 |   *** | MONSTER |
2 metric are OUT OF RANGE!
end_line (Begins at: 486 Ends at: 495)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
start_line (Begins at: 497 Ends at: 509)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
join_lines (Begins at: 511 Ends at: 538)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
extend_line (Begins at: 540 Ends at: 594)
CalledNBR:    |       7 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
get_ptr (Begins at: 596 Ends at: 607)
LOC:          |      12 |       |      OK |
metrics are OK
alloc_lines_bufs (Begins at: 609 Ends at: 624)
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
read_next (Begins at: 626 Ends at: 637)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
