[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.to.vect/lines_io.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.to.vect/lines_io.c functions
write_line (Begins at: 47 Ends at: 90)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 44 | | OK |
metrics are OK
write_ln (Begins at: 95 Ends at: 160)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 66 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
