[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.path/main.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:30 EST 2007
Hello hamish,
ANALYSIS
display/d.path/main.c functions
main (Begins at: 30 Ends at: 195)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      52 |     * |         |
LOC:          |     166 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
