[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.path/select.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:30 EST 2007
Hello hamish,
ANALYSIS
display/d.path/select.c functions
path (Begins at: 17 Ends at: 149)
Complexity: | 19 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 48 | * | |
LOC: | 133 | * | |
metrics are OK
display (Begins at: 152 Ends at: 165)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
