[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.contour/cont.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.contour/cont.c functions
contour (Begins at: 41 Ends at: 213)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      43 |     * |         |
LOC:          |     173 |     * |         |
metrics are OK
getnewcell (Begins at: 221 Ends at: 238)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
newedge (Begins at: 242 Ends at: 264)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
findcrossing (Begins at: 272 Ends at: 326)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
getpoint (Begins at: 332 Ends at: 377)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
checkedge (Begins at: 382 Ends at: 390)
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
