[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.contour/main.c |no clones | 0 monsters | 1 warnings
Thu Mar 1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 53 Ends at: 220)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     168 |     * |         |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 223 Ends at: 239)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
getlevels (Begins at: 243 Ends at: 341)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      26 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
displaceMatrix (Begins at: 349 Ends at: 373)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
