[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.to.vect/areas.c |2
	clones ( curses.c graphics.c mouse.c signature.c plot.c
	main.c main.c main.c main.c main.c main.c graphics.c
	graphics.c graphics.c graphics.c graphics.c c_update.c
	d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
	raster_rgb.c raster_rgb.c Get_location.c com_proto.c
	com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
	i_face.c main.c main.c level_two.c main.c build.c line.c
	read_nat.c areas.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Mar  1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.to.vect/areas.c functions
extract_areas (Begins at: 108 Ends at: 154)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
update_list (Begins at: 162 Ends at: 322)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     161 |     * |         |
metrics are OK
end_vline (Begins at: 327 Ends at: 335)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
end_hline (Begins at: 337 Ends at: 345)
LOC:          |       9 |       |      OK |
metrics are OK
start_vline (Begins at: 350 Ends at: 362)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
start_hline (Begins at: 364 Ends at: 376)
LOC:          |      13 |       |      OK |
metrics are OK
get_ptr (Begins at: 380 Ends at: 417)
LOC:          |      38 |       |      OK |
metrics are OK
nabors (Begins at: 419 Ends at: 485)
CalledNBR:    |       4 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
read_next (Begins at: 489 Ends at: 498)
LOC:          |      10 |       |      OK |
metrics are OK
alloc_areas_bufs (Begins at: 503 Ends at: 528)
CalledNBR:    |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
equiv_areas (Begins at: 533 Ends at: 600)
CalledNBR:    |       7 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
map_area (Begins at: 602 Ends at: 631)
Complexity:   |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
add_to_list (Begins at: 635 Ends at: 668)
Complexity:   |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
assign_area (Begins at: 673 Ends at: 686)
Complexity:   |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
more_areas (Begins at: 690 Ends at: 705)
LOC:          |      16 |       |      OK |
metrics are OK
more_equivs (Begins at: 709 Ends at: 724)
LOC:          |      16 |       |      OK |
metrics are OK
update_width (Begins at: 727 Ends at: 754)
Complexity:   |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  more_equivs  more_areas
In raster/r.to.vect/areas.c clones of  more_areas are:
	raster/r.to.vect/areas.c  more_equivs
In raster/r.to.vect/areas.c clones of  more_equivs are:
	raster/r.to.vect/areas.c  more_areas
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
