[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.to.vect/areas_io.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:36 EST 2007
Hello martinl,
ANALYSIS
raster/r.to.vect/areas_io.c functions
write_boundary (Begins at: 35 Ends at: 75)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 41 | | OK |
metrics are OK
write_bnd (Begins at: 80 Ends at: 146)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 67 | | OK |
metrics are OK
write_smooth_bnd (Begins at: 153 Ends at: 254)
Complexity: | 15 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 102 | | OK |
metrics are OK
write_area (Begins at: 257 Ends at: 373)
Complexity: | 17 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 117 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
