[GRASS-QA] GRASS QA: glynn |
./grass6/raster/wildfire/r.spread/display.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:27 EST 2007
Hello glynn,
ANALYSIS
raster/wildfire/r.spread/display.c functions
display_init (Begins at: 24 Ends at: 123)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 50 | * | |
LOC: | 100 | | OK |
metrics are OK
draw_a_cell (Begins at: 126 Ends at: 164)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 39 | | OK |
metrics are OK
draw_a_burning_cell (Begins at: 167 Ends at: 176)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 10 | | OK |
metrics are OK
display_close (Begins at: 179 Ends at: 182)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
