[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/attr.c |no clones | 0 monsters | 1 warnings
Thu Mar 1 19:38:27 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/attr.c functions
del_cat (Begins at: 18 Ends at: 49)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
add_cat (Begins at: 51 Ends at: 92)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
new_record (Begins at: 100 Ends at: 155)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
display_cats (Begins at: 159 Ends at: 243)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      37 |     * |         |
LOC:          |      85 |       |      OK |
metrics are OK
copy_cats (Begins at: 246 Ends at: 368)
Complexity:   |      19 |     * |         |
CalledNBR:    |      47 |     * |         |
LOC:          |     123 |     * |         |
metrics are OK
display_attributes (Begins at: 371 Ends at: 497)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      64 |    ** | Warning |
LOC:          |     127 |     * |         |
at least 1 values are close to an outlier please consider revising code
check_record (Begins at: 504 Ends at: 570)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
