[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/read_nat.c
|1 clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c
com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
i_face.c main.c main.c level_two.c main.c build.c line.c
read_nat.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:35 EST 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/read_nat.c functions
V1_read_line_nat (Begins at: 50 Ends at: 64)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
V1_read_next_line_nat (Begins at: 67 Ends at: 112)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 46 | | OK |
metrics are OK
V2_read_line_nat (Begins at: 118 Ends at: 135)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
metrics are OK
V2_read_next_line_nat (Begins at: 141 Ends at: 196)
Complexity: | 8 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 56 | | OK |
metrics are OK
Vect__Read_line_nat (Begins at: 199 Ends at: 320)
Complexity: | 27 | ** | Warning |
CalledNBR: | 23 | | OK |
LOC: | 122 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
V1_read_line_nat
In lib/vector/Vlib/read_nat.c clones of V1_read_line_nat are:
lib/gis/get_row.c G_get_raster_row_nomask
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
