[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/open.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:35 EST 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/open.c functions
open_old_dummy (Begins at: 41 Ends at: 41)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 1 | | OK |
metrics are OK
fatal_error (Begins at: 59 Ends at: 89)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 31 | | OK |
metrics are OK
Vect_set_open_level (Begins at: 92 Ends at: 115)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
LOC: | 24 | | OK |
metrics are OK
Vect__open_old (Begins at: 118 Ends at: 368)
Complexity: | 31 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 100 | *** | MONSTER |
LOC: | 251 | ** | Warning |
1 metric are OUT OF RANGE!
Vect_open_old (Begins at: 371 Ends at: 388)
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
Vect_open_update (Begins at: 391 Ends at: 424)
LOC: | 34 | | OK |
metrics are OK
Vect_open_old_head (Begins at: 427 Ends at: 439)
LOC: | 13 | | OK |
metrics are OK
Vect_open_update_head (Begins at: 442 Ends at: 468)
LOC: | 27 | | OK |
metrics are OK
Vect_open_new (Begins at: 471 Ends at: 544)
Complexity: | 6 | | OK |
CalledNBR: | 36 | * | |
LOC: | 74 | | OK |
metrics are OK
Vect_coor_info (Begins at: 553 Ends at: 589)
CalledNBR: | 7 | | OK |
LOC: | 37 | | OK |
metrics are OK
Vect_maptype_info (Begins at: 598 Ends at: 624)
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
Vect_open_topo (Begins at: 627 Ends at: 694)
Complexity: | 7 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 68 | | OK |
metrics are OK
Vect_open_spatial_index (Begins at: 703 Ends at: 766)
CalledNBR: | 8 | | OK |
LOC: | 64 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
