[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/read_ogr.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Mar 2 12:03:38 EST 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/read_ogr.c functions
cache_feature (Begins at: 29 Ends at: 118)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 90 | | OK |
metrics are OK
V1_read_next_line_ogr (Begins at: 121 Ends at: 205)
Complexity: | 15 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 85 | | OK |
metrics are OK
V2_read_next_line_ogr (Begins at: 208 Ends at: 213)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
read_line (Begins at: 219 Ends at: 271)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 53 | | OK |
metrics are OK
V2_read_line_ogr (Begins at: 274 Ends at: 344)
Complexity: | 12 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 71 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
