[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.rast/do_lines.c |no clones | 0 monsters | 1 warnings
Sat Mar 3 09:10:46 EST 2007
Hello markus,
ANALYSIS
vector/v.to.rast/do_lines.c functions
do_lines (Begins at: 11 Ends at: 104)
Complexity:   |      22 |     * |         |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      20 |       |      OK |
LOC:          |      94 |       |      OK |
at least 1 values are close to an outlier please consider revising code
plot_line (Begins at: 107 Ends at: 120)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
v2angle (Begins at: 127 Ends at: 132)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
deg_angle (Begins at: 136 Ends at: 164)
LOC:          |      29 |       |      OK |
metrics are OK
plot_points (Begins at: 167 Ends at: 173)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
