[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.random/random.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 3 19:52:24 EST 2007
Hello brad,
ANALYSIS
raster/r.random/random.c functions
execute_random (Begins at: 12 Ends at: 203)
Complexity: | 25 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 77 | ** | Warning |
LOC: | 192 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
cpvalue (Begins at: 206 Ends at: 218)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
cell_as_dbl (Begins at: 220 Ends at: 231)
ParamNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
set_to_null (Begins at: 234 Ends at: 245)
CalledNBR: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
is_null_value (Begins at: 248 Ends at: 265)
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
