[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.random/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 3 19:52:24 EST 2007
Hello brad,
ANALYSIS
raster/r.random/main.c functions
main (Begins at: 12 Ends at: 185)
Complexity: | 18 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 54 | * | |
LOC: | 174 | * | |
metrics are OK
has_percent (Begins at: 187 Ends at: 193)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
do_info_exit (Begins at: 196 Ends at: 205)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
