[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/find_file.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 05:54:18 EST 2007
Hello glynn,
ANALYSIS
lib/gis/find_file.c functions
G__find_file (Begins at: 5 Ends at: 106)
Complexity: | 11 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 102 | | OK |
metrics are OK
G_find_file (Begins at: 108 Ends at: 146)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 39 | | OK |
metrics are OK
G_find_file2 (Begins at: 148 Ends at: 154)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
