[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.build/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 07:40:10 EST 2007
Hello martinl,
ANALYSIS
vector/v.build/main.c functions
main (Begins at: 24 Ends at: 139)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 39 | * | |
LOC: | 116 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
