[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/diglib/plus_line.c |no clones | 0 monsters | 0 warnings
Tue Mar 6 09:56:58 EST 2007
Hello martinl,
ANALYSIS
lib/vector/diglib/plus_line.c functions
dig_add_line (Begins at: 50 Ends at: 153)
Complexity:   |      16 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |     104 |       |      OK |
metrics are OK
dig_del_line (Begins at: 156 Ends at: 226)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
dig_line_get_area (Begins at: 229 Ends at: 258)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
dig_line_set_area (Begins at: 261 Ends at: 280)
CalledNBR:    |       0 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
dig_line_set_box (Begins at: 283 Ends at: 307)
Complexity:   |       1 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
dig_line_get_box (Begins at: 310 Ends at: 323)
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
