[GRASS-QA] GRASS QA: markus | ./grass6/lib/proj/convert.c |no
clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 13:58:11 EST 2007
Hello markus,
ANALYSIS
lib/proj/convert.c functions
GPJ_grass_to_wkt (Begins at: 53 Ends at: 85)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 33 | | OK |
metrics are OK
GPJ_grass_to_osr (Begins at: 87 Ends at: 255)
Complexity: | 18 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 63 | ** | Warning |
LOC: | 169 | * | |
at least 1 values are close to an outlier please consider revising code
GPJ_osr_to_grass (Begins at: 257 Ends at: 684)
Complexity: | 44 | *** | MONSTER |
ParamNBR: | 5 | * | |
CalledNBR: | 94 | *** | MONSTER |
LOC: | 428 | *** | MONSTER |
3 metric are OUT OF RANGE!
GPJ_wkt_to_grass (Begins at: 686 Ends at: 707)
Complexity: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
GPJ_set_csv_loc (Begins at: 713 Ends at: 738)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 26 | | OK |
metrics are OK
DatumNameMassage (Begins at: 772 Ends at: 819)
Complexity: | 5 | | OK |
LOC: | 48 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
