[GRASS-QA] GRASS QA: martinl |
./grass6/lib/vector/diglib/plus_area.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 13:58:12 EST 2007
Hello martinl,
ANALYSIS
lib/vector/diglib/plus_area.c functions
dig_build_area_with_line (Begins at: 66 Ends at: 176)
Complexity: | 13 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 111 | | OK |
metrics are OK
dig_add_area (Begins at: 179 Ends at: 252)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 74 | | OK |
metrics are OK
dig_area_add_isle (Begins at: 255 Ends at: 291)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 37 | | OK |
metrics are OK
dig_area_del_isle (Begins at: 294 Ends at: 340)
Complexity: | 5 | | OK |
LOC: | 47 | | OK |
metrics are OK
dig_del_area (Begins at: 343 Ends at: 434)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 92 | | OK |
metrics are OK
dig_area_set_box (Begins at: 437 Ends at: 468)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 32 | | OK |
metrics are OK
dig_angle_next_line (Begins at: 471 Ends at: 554)
Complexity: | 12 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 84 | | OK |
metrics are OK
dig_node_angle_check (Begins at: 557 Ends at: 606)
CalledNBR: | 9 | | OK |
LOC: | 50 | | OK |
metrics are OK
dig_add_isle (Begins at: 609 Ends at: 688)
CalledNBR: | 18 | | OK |
LOC: | 80 | | OK |
metrics are OK
dig_isle_set_box (Begins at: 691 Ends at: 716)
LOC: | 26 | | OK |
metrics are OK
dig_del_isle (Begins at: 719 Ends at: 752)
LOC: | 34 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
