[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/diglib/plus.c |3
clones ( plus.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 13:58:13 EST 2007
Hello martinl,
ANALYSIS
lib/vector/diglib/plus.c functions
dig_init_plus (Begins at: 49 Ends at: 123)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 75 | | OK |
metrics are OK
dig_free_plus_nodes (Begins at: 126 Ends at: 157)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 32 | | OK |
metrics are OK
dig_free_plus_lines (Begins at: 160 Ends at: 195)
Complexity: | 3 | | OK |
LOC: | 36 | | OK |
metrics are OK
dig_free_plus_areas (Begins at: 198 Ends at: 231)
Complexity: | 5 | | OK |
LOC: | 34 | | OK |
metrics are OK
dig_free_plus_isles (Begins at: 234 Ends at: 267)
CalledNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
dig_free_plus (Begins at: 270 Ends at: 291)
CalledNBR: | 6 | | OK |
LOC: | 22 | | OK |
metrics are OK
dig_load_plus (Begins at: 294 Ends at: 372)
Complexity: | 11 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 79 | | OK |
metrics are OK
dig_write_plus_file (Begins at: 375 Ends at: 432)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 58 | | OK |
metrics are OK
dig_write_nodes (Begins at: 435 Ends at: 461)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 27 | | OK |
metrics are OK
dig_write_lines (Begins at: 464 Ends at: 491)
LOC: | 28 | | OK |
metrics are OK
dig_write_areas (Begins at: 494 Ends at: 521)
LOC: | 28 | | OK |
metrics are OK
dig_write_isles (Begins at: 524 Ends at: 540)
LOC: | 17 | | OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
dig_write_isles dig_write_areas dig_write_lines
In lib/vector/diglib/plus.c clones of dig_write_isles are:
lib/vector/diglib/plus.c dig_write_areas
lib/vector/diglib/plus.c dig_write_lines
In lib/vector/diglib/plus.c clones of dig_write_lines are:
lib/vector/diglib/plus.c dig_write_isles
In lib/vector/diglib/plus.c clones of dig_write_areas are:
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
