[GRASS-QA] GRASS QA: martinl |
./grass6/lib/vector/diglib/plus_node.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 13:58:13 EST 2007
Hello martinl,
ANALYSIS
lib/vector/diglib/plus_node.c functions
dig_node_add_line (Begins at: 59 Ends at: 122)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 6 | | OK |
LOC: | 64 | | OK |
metrics are OK
dig_add_node (Begins at: 125 Ends at: 166)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 42 | | OK |
metrics are OK
dig_which_node (Begins at: 169 Ends at: 225)
Complexity: | 6 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 57 | | OK |
metrics are OK
dig_node_line_angle (Begins at: 228 Ends at: 248)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 21 | | OK |
metrics are OK
dist_squared (Begins at: 251 Ends at: 258)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
