[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/at_exit_funcs.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 8 08:25:11 EST 2007
Hello benjamin,
ANALYSIS
gem/at_exit_funcs.c functions
exit_env (Begins at: 28 Ends at: 57)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 30 | | OK |
metrics are OK
exit_tmp (Begins at: 60 Ends at: 98)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 39 | | OK |
metrics are OK
exit_db (Begins at: 101 Ends at: 194)
Complexity: | 23 | * | |
CalledNBR: | 39 | * | |
LOC: | 94 | | OK |
metrics are OK
exit_msg (Begins at: 197 Ends at: 208)
Complexity: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
