[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/actions.c |no clones |
1 monsters | 5 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 8 08:25:10 EST 2007
Hello benjamin,
ANALYSIS
gem/actions.c functions
check_extension (Begins at: 28 Ends at: 74)
Complexity: | 6 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 23 | | OK |
LOC: | 47 | | OK |
metrics are OK
unpack_extension (Begins at: 81 Ends at: 171)
Complexity: | 17 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
query_extension (Begins at: 174 Ends at: 204)
Complexity: | 2 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 20 | | OK |
LOC: | 31 | | OK |
at least 1 values are close to an outlier please consider revising code
print_cfg (Begins at: 209 Ends at: 224)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
source_install (Begins at: 229 Ends at: 418)
Complexity: | 16 | * | |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 93 | *** | MONSTER |
LOC: | 190 | * | |
1 metric are OUT OF RANGE!
bin_install (Begins at: 424 Ends at: 570)
Complexity: | 8 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 147 | * | |
at least 2 values are close to an outlier please consider revising code
test_install (Begins at: 573 Ends at: 729)
Complexity: | 13 | | OK |
CalledNBR: | 83 | ** | Warning |
LOC: | 157 | * | |
uninstall (Begins at: 736 Ends at: 830)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 95 | | OK |
metrics are OK
source_clean (Begins at: 833 Ends at: 866)
Complexity: | 4 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 34 | | OK |
metrics are OK
restore (Begins at: 872 Ends at: 931)
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 60 | | OK |
metrics are OK
list_extensions (Begins at: 937 Ends at: 961)
LOC: | 25 | | OK |
metrics are OK
run_post (Begins at: 968 Ends at: 1030)
Complexity: | 11 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 63 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
