[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/reg_entries.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 8 08:25:12 EST 2007
Hello benjamin,
ANALYSIS
gem/reg_entries.c functions
is_submenu (Begins at: 35 Ends at: 53)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
check_ext_menu (Begins at: 55 Ends at: 84)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
new_submenu (Begins at: 86 Ends at: 156)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 71 | | OK |
metrics are OK
new_item (Begins at: 164 Ends at: 217)
ParamNBR: | 4 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 54 | | OK |
metrics are OK
register_entries_gisman (Begins at: 219 Ends at: 391)
Complexity: | 19 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 54 | * | |
LOC: | 173 | * | |
metrics are OK
register_entries_gisman2 (Begins at: 393 Ends at: 430)
CalledNBR: | 10 | | OK |
LOC: | 38 | | OK |
metrics are OK
deregister_entries_gisman (Begins at: 432 Ends at: 607)
Complexity: | 17 | * | |
CalledNBR: | 56 | * | |
LOC: | 176 | * | |
metrics are OK
deregister_entries_gisman2 (Begins at: 614 Ends at: 643)
LOC: | 30 | | OK |
metrics are OK
restore_entries_gisman (Begins at: 649 Ends at: 824)
Complexity: | 21 | * | |
CalledNBR: | 58 | * | |
LOC: | 176 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
