[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/reg_deps.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 8 08:25:11 EST 2007
Hello benjamin,
ANALYSIS
gem/reg_deps.c functions
depstr (Begins at: 31 Ends at: 74)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 44 | | OK |
metrics are OK
register_extension (Begins at: 82 Ends at: 208)
Complexity: | 16 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 41 | * | |
LOC: | 127 | * | |
metrics are OK
deregister_extension (Begins at: 214 Ends at: 299)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 86 | | OK |
metrics are OK
check_dependencies (Begins at: 307 Ends at: 410)
Complexity: | 17 | * | |
CalledNBR: | 29 | | OK |
LOC: | 104 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
